RCS UK -  Ad - Launch
07 days 01 hours 35 minutes 14 seconds
pan flashing for skylight
September 2, 2012 at 8:17 a.m.
max
I had to fabricate and install this skylight pan flashing. At 34 ft. anyone top this or do I have the record.
September 23, 2012 at 7:53 a.m.
ottawa_roofer
Velux is my preference, but i bow to you. I once did a bank of 4 cirb mounted lites, but nothing like that. Good pic, thanks. B)
September 3, 2012 at 8:49 p.m.
TO be honest Tom, I don't even know. 99% of the ones I work on don't get a cricket. Sometimes, I look at the roof and know I'd better add one! :)
Here's a typical replacement I did. The ends extend about 8" past each corner.
September 3, 2012 at 8:29 p.m.
Tinner...Been std, (cricket required per UBC/IBC/IRC), as long as I can remember...Is it 24" or 30"? max w/o?
Crickets are pretty-much std/the norm on most res sloped roofs.
There's a lot of roofs performing just fine in complete opposition of std/typical/"code" rqrmnts/roofing practices....
September 3, 2012 at 6:59 p.m.
max
TomB Said: Why was it replaced, if it was performing? Do it once; Do it right. BTW; We just completed a pool house roof, that had extensive skylights, (raised appropriately, w/crickets)....It was an earth-covered roof as well.
There was a leak on the otherside of that large vent that had been leaking for a long time. Carpenters had to reframe the whole area it was so bad. They damaged the skylight pan in the process so that was the reason. It was performing just fine. Been fine now for 2 years.4/12 roof
September 3, 2012 at 3:54 p.m.
I've done several similar ones. I think you beat me by several feet though. My largest chimney without a cricket was 8'+. Bent in a full 36" sheet of LLC, with about 10" of it up.
Tom, crickets may be reccomended, but I doubt required. Any roofer could flash thousands of chimneys, never use a cricket, and they'll never leak. Now, take a jackleg, and even with a cricket, I think his batting average will be around 50%. It will come down to the installer every time to get it right.
September 3, 2012 at 12:44 p.m.
The longest one I did was 80 Ft. All home made using Lexicon clear panels. It was over a pool also. I wish I had a picture. I do recall putting in expansion joints. Was just a single row about 60 inches wide in a wood shingle roof. Never had a call back on it. Been is service 12 years before I left PA.
September 3, 2012 at 11:52 a.m.
September 3, 2012 at 10:33 a.m.
40 ft. span cut in half to allow for drainage in both directions= 20 ft. run X 1/4" = 5" rise at center = 2X6 upper "curb"
That would meet code with a minimum of additional expense. Next time.
September 3, 2012 at 10:31 a.m.
September 3, 2012 at 10:18 a.m.
max
yes woody on a 40 ft brake
September 3, 2012 at 10:17 a.m.
max
This skylight has been here for 20 years+. All I was asked to do was replace what was there. Are you saying you would advise the homeowner to spend thousands of dollars to modify a custom skylight to meet IBC/IRC? BY the was this is over a pool, if that makes any differnce.
September 3, 2012 at 8:28 a.m.
As a consultant, I wouldn't buy that line....Raise'em up & install crickets as per IBC/IRC.
September 3, 2012 at 8:08 a.m.
max
At the present time, unit skylights are required to be tested and labeled in accordance with the same standard in both the IRC and IBC. Unit skylights will also be exempt from a requirement of the IRC and IBC for saddle or cricket flashing of large roof openings. It is more appropriate for the installer of these skylights to instead rely upon the installation instructions of the skylight manufacturers, as currently occurs for windows.
September 2, 2012 at 6:36 p.m.
How do you skirt IBC/IRC cricket requirements?
MBCEA - Banner - Job Board
