BITEC-StormBreaker-Sidebar
TraceyDonels-June26-PeopleMakeRoofing-SidebarAd
RCS - Sidebar - L&L contest
IIBEC - Sidebar Ad - BES 2025
Roof Product idea
July 29, 2010 at 4:08 p.m.
Roofpump44
Looking for some advice. Our company is working on a product that can be used to drain water from flat roof tops. Basically the concept is a small portable solar powered rechargeable pump that will automatically turn on when water is present. No 110 volt required. It will drain water down to less than 1/2 inch- The pump will be able to drain 200 gallons per charge. Proposed target price is less than $100.00. Any feedback would be greatly appreciated Thanks
July 31, 2010 at 8:12 p.m.
Certain membranes aren't effected by ponding water.I think it's a great products in cases where the owners can't afford a new roof.
July 30, 2010 at 7:56 a.m.
Roofpump44
Just looking for feedback from folks in the industry. Based on the responses it appears that someone (Tim?) had a similar post. Also, we would be interested in some beta field testing on initial production pilot runs. If you are interested in getting some samples you can email me directly at Jeff.schopperle@itt.com
Thanks
July 29, 2010 at 9:44 p.m.
Roofpump44
I guess this concept/ idea was posted before. It is not a siphon pump but rather a centrifugal pump. The product would only sit in the low spots that retain the most water. If there was multiple spots then you would need several pumps. Again any feed back would be appreciated Thanks
July 29, 2010 at 6:09 p.m.
jcagle9595
Hi Tim. New screen name, eh?
Westlake - Banner Ad - Hail protection you can rely on (MCS)
SRS - Sidebar Ad - Your complete source for solar solutions & building products
Metal Sales - Sidebar Ad
