tremco-uk--ad
Pic of the Day pt.2
December 14, 2009 at 3:30 p.m.
dennis
After
That was granule surface I&W on the cricket and on the valley. Bottom corner was a mish mash of i&w, caulk, and small pieces of copper.
December 16, 2009 at 2:32 p.m.
Here's another that kind of illustrates my goal:
December 16, 2009 at 2:03 p.m.
I see. (chuckling) I would have to respond that I must be showing my colors as a sensate modernist with just a smidgeon of new-age psychology peppering the surface then. In that spirit I'll go ahead and throw in an A+ for the consistency of your evaluation process. I have a slightly more 'liberal' way of grading, but true acceptance is probably just as demanding. Where I differ on the A+ issue is maybe kind of interesting or maybe not, depending on who's doing the thinking. Execution and function make up the A to F grades for me. Since I don't really acknowledge perfection as attainable, the '+' relates to something different. In school they would only give a plus for exceeding the scope of an assignment, which didn't relate to perfection but was something other. I mark down for flaws, commencing with A and running out of room with F, although there is in fact a purple zone (infra-red actually) that starts out at F and goes progressively lower until it reaches the unplumbed depths of wanting to nuke somebody. The plus is a non-linear extension, an imperfect 'A' that is also art. Something that not only has a function but celebrates its function. When I squint my eyes a little and view it not merely as a set of functioning parts but as an entity in its own right, beyond its intended use there may or may not be some extra side to it. Smudge posted up a piece of lead work once that had that extra quality going on.
December 16, 2009 at 12:32 p.m.
Jed, whether or not Dennis used caulk or lead, please elaborate on your prohibition against caulk w/bricks and mortar. I am assuming that you hold to the notion that both bricks and mortar are porous materials and so caulk would actually trap moisture in the groove and eventually separate from the masonry through wet/dry cycles. Is that the case here? If it isn't, I am all ears. If it is, I have to report that I have had outstanding success with caulk used in brick and mortar, although there is a bit of a demanding process I have to go through to achieve it.
As far as Dennis's workmanship goes, I truly can't imagine him touching anything that doesn't end up looking beautiful when it's completed. Amazingly talented guy. Otoh, I would very much like to see a shot of the corners looking up-slope because I just cannot quite picture how those two small shoulders have been handled. I agree in principle about the reach of the return, but somehow I presume it has been mindfully handled and will perform as hoped for.
As far as the expanse of the metal on the back goes, nobody will ever see it except us, we like copper, it matches the scale of the cricket, and simple is good. Except for my reservations about the way the corners interface (since I can't see them) I give it an A+
December 15, 2009 at 8:07 p.m.
Nah Woody! Me too. And got called a hack at another forum for it too! :laugh: :laugh:
December 15, 2009 at 9:25 a.m.
dennis
Cleveland, Ohio
Same shingles, about 4yrs old
Tied into copper valley. Rolled gable, with rolled eave/valley at bottom (that's another story)
multiply that lower number x 8
yep, cheap granule surface ice and water. If applied to old dirty roof boards, sometimes we can peel it off. Often we just go over if the deck is solid.
I'll take the A-. We can always do better. (given more time and money)
Thanks for the compliments.
December 15, 2009 at 12:43 a.m.
I give it an A minus. Counter step the backside as well and its an A plus. But hey im just picky. So, Good job Dennis! :) Sometimes they look better the way you did it anyways due to them doing it the same way before and leaving the marks on the chimney. Its better to cover them back up sometimes by reinstalling the way it was before.
December 14, 2009 at 7:10 p.m.
wywoody Nice call on the rolled gable comment . I scanned the pic looking for little anomalies or unique features . Missed that one/ B) :) ;) B)
December 14, 2009 at 5:04 p.m.
Dennis That is a nice clean professional application. Nice work nice lead work . Am I seeing an older shingle on the other slope ?
December 14, 2009 at 4:24 p.m.
johnny5
Thats nice looking work. I have not seen a lot of that kinda thing on an economy comp roof here on the west coast. Where is that?
RCS Canada - Banner Ad - Canada Microsite Launch
Hi-Peak - TalentSearch -
SPRI  Ad - DORA Directory
