03 days 13 hours 41 minutes 34 seconds
Partial Roof Under Deck (Attn Vaaa)
April 18, 2010 at 11:11 a.m.
doublejz
I was advised from contractor talk dot com to join here and contact Vaaa regarding my current project.
I have a deck which is directly above a 1 car garage (thats leaking). The goal here is to remove the flooring of the deck, fix the roof and replace the deck floor. Then from there, tear down the walls of the garage and redo them one at a time.
However, I started removing the deck flooring today and found strips of light weight tin between each joist as the roof top.
[IMG]http://i903.photobucket.com/albums/ac239/doublejz00/Deck/deck03.jpg[/IMG]
Which has tons of rust holes letting water into the garage. [IMG]http://i903.photobucket.com/albums/ac239/doublejz00/Deck/deck04.jpg[/IMG]
Underneath the tin is the insulation then the garage ceiling. [IMG]http://i903.photobucket.com/albums/ac239/doublejz00/Deck/deck06.jpg[/IMG]
[IMG]http://i903.photobucket.com/albums/ac239/doublejz00/Deck/garage01.jpg[/IMG]
Ontop of all of that, the roof posts are not up to par as well. [IMG]http://i903.photobucket.com/albums/ac239/doublejz00/Deck/deck07.jpg[/IMG]
So my issue is, I obviously can't do a torch down roof without raising the deck up a little and even with that I need some slope towards the gutter. Underdecking won't work with having a ceiling in the garage. So that leaves me towards the idea of getting a roll of EPDM but I'm still not sure how I'd create slope.
For dimensions the part of the deck that covers the garage is 12.5'd x 20'w. It appears that the ledger is nailed to another board which is anchored to the basement wall. Can't confirm this 100% until I get that far with tearing up deck. There are no joist hangers and they are 16" centers.
Here are some more pictures of the deck.
[IMG]http://i903.photobucket.com/albums/ac239/doublejz00/Deck/deck09.jpg[/IMG]
[IMG]http://i903.photobucket.com/albums/ac239/doublejz00/Deck/garage08.jpg[/IMG]
[IMG]http://i903.photobucket.com/albums/ac239/doublejz00/Deck/garage10.jpg[/IMG]
[IMG]http://i903.photobucket.com/albums/ac239/doublejz00/Deck/deck15.jpg[/IMG]
Don't mind the mess, trying to see what I have to work with before I jump in 100%. [IMG]http://i903.photobucket.com/albums/ac239/doublejz00/Deck/deck16.jpg[/IMG]
[IMG]http://i903.photobucket.com/albums/ac239/doublejz00/Deck/deck17.jpg[/IMG]
[IMG]http://i903.photobucket.com/albums/ac239/doublejz00/Deck/deck14.jpg[/IMG]
Seeing that the side wall of the garage is the where the majority of the load is being supported from and that and the person who built this really cut corners everywhere.. I'd like to level the whole garage, build a footing and redo it with blocks. It's just not going to be worth it all if I have to take the deck roof off too. [IMG]http://i903.photobucket.com/albums/ac239/doublejz00/Deck/deck12.jpg[/IMG]
Any suggestions on how to put a roof on the garage (under the deck) without leveling it and starting again will be greatly appreciated.
April 23, 2010 at 3:04 p.m.
doublejz
Well, thanks for the advise all. The door currently sits 3/4" off the deck but the frame itself is actually on the deck. It also looks like the builder of this POS put the first board down then built the wall. In other words, about 1" of a 2x6 is visible under the wall. How hard is it to apply the membrane correctly? I've never touched the stuff. I'd assume it is like vinyl and you would want to glue portions at a time to keep it tight and even possibly use a heatgun to remove imperfections, no?
Also you suggested PVC over EPDM. Any particular reason? Also, how well does this stuff hold up in snow?
April 20, 2010 at 4:47 p.m.
RandyB1986
Egg.....that is amazing! I sent Double over here from another site.....maybe some people are lurking from that site as well.
April 20, 2010 at 1:41 p.m.
Nice solid reply imho. btw, get a load of the ratio of views to replies on this thread. Amazing.
April 19, 2010 at 7:07 p.m.
WildBill
Coat it with Alsan Flashing. Reinforce all the weak spots with fabric. Put the boards back.
http://vimeo.com/7167709
April 19, 2010 at 4:30 p.m.
The FNRUFR
http://www.skelleruproofing.co.nz/deck_colour.aspxhttp://www.skelleruproofing.co.nz/deck_colour.aspx
April 19, 2010 at 4:18 p.m.
The FNRUFR
option 1# remake the tin .have a break on site so you can fab nice panels
option 2# remove 5/4 re sheet with 3/4 and pvc like decking then when you rework your walls drop it a inch or so for drainge
April 18, 2010 at 9:33 p.m.
RandyB1986
Double.....Check this out. It is somewhat similar to your house. Vaa did this job.
http://www.rooferscoffeeshop.com/rcs/view_thread.asp?threadid=21639&forumid=8&pn=
April 18, 2010 at 12:42 p.m.
@$#_*$(&$*&@(*!@@($*&&*%&@)*@!_(#)!*&(*@&%)(@*%)#@(%+_@%(@&%&@$#)(!$)%*@( Translation You Can't
Elevate - Banner Ad - Industry-Leading Performance (Max PVC)
SRS -  Ad - TopShield TS20
IKO -  - Dynasty
Malco -  - Veto HVAC Kits
NFRC - - Weather the Storm
