BITEC-StormBreaker-Sidebar
METALCON - Sidebar Ad SPAN - METALCON 2025
World of Concrete - Sidebar Ad - Learn More 2026
Sherwin-Williams - Sidebar Ad - MetalRoofingElements - Hail
IIBEC - Sidebar Ad - BES 2025
Panels for marine environments
« Back To All Things Metal
February 6, 2024 at 10:57 a.m.
AnnaLockhart
What types of panels are recommended in marine environments? Concealed or exposed panels?
August 9, 2024 at 11:34 p.m.
amorapotter
According to AEP Span:
We recommend using panels with concealed fasteners in marine environments, because of the harsh conditions. View AEP Span concealed Fastener metal roofingModifying the paint system for these environments is also recommended, using high-build primers and paints. Contact AEP Span for more information.
-AnnaLockhart
These panels help to minimize corrosion and other damage caused by the marine atmosphere.
May 10, 2024 at 11:24 p.m.
PatrickNitzsche
Aluminum is compatible with coastal climates because it does not rust. Therefore, sea salt sprayed from water will have less effect on the aluminum surface. To best protect your roof, you should apply a layer of protective paint to protect your roof from rust.
March 5, 2024 at 8:25 p.m.
Debound
Use panels with concealed fasteners rather than exposed fasteners, as they minimize the risk of water penetration, rust, and leakage. They also provide a smoother and cleaner appearance https://boatpowered.com/marine-solar-panels
March 5, 2024 at 12:59 a.m.
Nibeshe
Use panels with high-quality coatings that can resist the harsh conditions of the marine environment, such as high-build primers and paints, fluoropolymer coatings, or galvalume coatings. They also enhance the durability and color retention of the panels https://www.steelscape.com/metal-in-coastal-regions-blog-2/ a small world cup
February 6, 2024 at 10:58 a.m.
AnnaLockhart
SOPREMA - Banner Ad - Sop
Metal Sales - Sidebar Ad
