MRCA - Sidebar Ad - 2025 MRCA Conference & Expo
MuleHide-Sidebar-Q1
Hi-Peak - Sidebar - NWIR
Ice Dams
January 21, 2010 at 3:29 p.m.
soldierboy
Has anyone in the North Country ever used a complete ventilation system? (Won't brand the name) We used allot of their products this past year to get the full warranty from the manufacturer. We would use their intake Edge vent and outside baffled ridge vent on the ridge line. We followed all of the manufactures specs and even did more than required.
Now, I have customers with large ice dams still on their home. Going down their block everyone has ice dams going on their roof. We spent extra time on labor and materials so this wouldn't be such a problem for them. Going into the new year I find myself complexed as to why we would spend the extra time and their money on installing this type of system. If I just put 6' of ice and water shield on their roofs I can save my future customers hundreds of dollars.
Facts: 1. Proper amount of insulation in the attic. 2. Proper ventilation system. 3. Checked their april air systems. 4. Checked their humidity in the attic and main floor. Nobody had more than 25% humidity on their main floors.
If what we have been taught about proper ventilation and insulation is correct and the fancy pant engineer's that put the numbers down. Wouldn't you believe that they wouldn't have ice dams upwards of 2' high?
What would you other roofers do?? We just want to be known as the roofer that didn't rip this homeowner off.
January 22, 2010 at 8:27 a.m.
soldierboy
dennis Said: Depends on what you consider a complete ventilation system. Some roofs have different ventilation requirements.
If I just put 6 of ice and water shield on their roofs I can save my future customers hundreds of dollars.
That wont stop the ice dams.
What I meant by the 6' of ice guard is.. If proper ventilation isn't going to stop their ice problem I could just do the bear minimum on ventilation and keep the water out by adding extra ice guard.
I also didn't want to bust out AirVent. But, that's the only products I have used for 10 years. When The "Edge" came out it was easier to use and less costly than using the combovent.
I would also love to install new rafters and make a cold roof for my customers, however in my area it takes everything we have just to get the homeowner to understand about some ventilation, attic insulation, and the use of roof baffles.
Any home that we have attic insulation installed in we put rafter baffles into. Then we will use the attic cat or equivilant to complete the job. Always have gone above for our customers what the basic or minimums by the state or local government are.
Just a few houses I don't think you will ever completely get rid of their ice dams. Unless, of course you install the cold roof system. By the way, great Job!! Maybe you could teach us how to sell that service??
Thanks for all the help so far. I am going to direct some of the homeowners that want to argue their points of views to this forum...
January 21, 2010 at 3:56 p.m.
dennis
"If I just put 6' of ice and water shield on their roofs I can save my future customers hundreds of dollars. "
That won't stop the ice dams.
Adams & Reese - Banner Ad - Law & Mortar Podcast Series
TRA-VideoBrochure-Sidebar
Ingage - Sidebar - OC 265x250
Metal Sales - Sidebar Ad
