IKO - Sidebar - Dynasty
Home Maintenance DIY Tips & Tricks
« Back To Fire, Storm, Tornado & Hurricane Relief
August 15, 2024 at 6:45 p.m.
parkerstevens
Share your own home maintenance tips or get advice on DIY projects.
Here are some tips as a contractor: https://www.propertystewards.com/services
  1. Regular HVAC Maintenance
    • Change Air Filters: Replace air filters every 1-3 months to keep your HVAC system running efficiently and improve indoor air quality.
    • Schedule Professional Inspections: Have your HVAC system serviced by a professional at least once a year to catch any issues before they become major problems. https://www.propertystewards.com/contact-info
  2. Check and Clean Gutters
    • Remove Debris: Clean your gutters and downspouts at least twice a year, ideally in the spring and fall, to prevent clogs and water damage.
    • Inspect for Damage: Look for signs of wear and tear, such as leaks or sagging, and repair or replace damaged sections as needed.
  3. Inspect Roof for Damage
    • Check Shingles: Look for missing or damaged shingles and replace them promptly to prevent leaks.
    • Look for Moss or Algae: Remove moss and algae to prevent roof damage and maintain curb appeal.
  4. Test Smoke and Carbon Monoxide Detectors
    • Monthly Tests: Test detectors monthly and replace batteries at least once a year.
    • Replace Units: Replace detectors every 10 years or as recommended by the manufacturer.
  5. Seal Gaps and Cracks
    • Weatherproofing: Use caulk or weatherstripping to seal gaps around windows and doors to improve energy efficiency and reduce drafts.
    • Inspect Regularly: Check for new gaps or cracks and address them promptly to maintain insulation.
  6. Clean Dryer Vents
    • Reduce Fire Risk: Clean the lint trap after each use and have the vent cleaned professionally at least once a year to prevent fire hazards and improve dryer efficiency.
Share your thoughts too!
RCS - Sidebar - L&L contest
Metal Sales - Sidebar Ad
MetalForming - Lunch & Learn sidebar - The Right Machinery With the Right Partner
SRS - Sidebar Ad - Your complete source for solar solutions & building products
