BITEC-StormBreaker-Sidebar
CT_SidebarAd 6-25
Drain Tarps
December 6, 2023 at 8:47 a.m.
Brodes96
I'm looking for some drain tarps to temporarily fix a leak/hole. The roof is a 10/12 peak if that helps. Looking for any advice/reccomendations.
January 8, 2024 at 1:08 a.m.
viahaiha
Polyethylene Tarps, commonly used and cost-effective, should be chosen for their durability. Look for a heavy-duty polyethylene tarp with reinforced edges. Canvas Tarps, on the other hand, are more durable and resistant to tearing, making them suitable for longer-term use. However, they tend to be heavier.
January 5, 2024 at 6:07 a.m.
Brodes96
I found the cause of the problem. For future reference, would something like this be suitable as a "quick fix"? https://www.tarpsnow.com/shop.html
December 28, 2023 at 1:55 a.m.
infestednide
Yes, tarps won't fix your roof permanently, and you should get to the bottom of what's causing it. If the damage is significant or if you are not sure what repairs are needed, it is best to get a professional's opinion.
December 25, 2023 at 12:48 a.m.
SphereyKalita
If you're dealing with a leak or hole in your roof and need a temporary solution, using a tarp can be a practical and effective option. Here are some recommendations and tips to guide you in selecting and installing drain tarps
  1. Tarp Material
   - Polyethylene Tarps These are commonly used and cost-effective. Look for a heavy-duty polyethylene tarp with reinforced edges for durability.
   - Canvas Tarps Canvas tarps are more durable and resistant to tearing, making them suitable for longer-term use. However, they tend to be heavier.
  1. Size and Coverage
   - Measure the area you need to cover accurately. Ensure the tarp is large enough to extend beyond the damaged section to prevent water from seeping in.
   - Consider a tarp with grommets along the edges for secure attachment. Reinforced edges can provide additional strength.
  1. UV Resistance
   - If the tarp will be exposed to sunlight for an extended period, choose one with UV resistance to prevent deterioration and ensure longevity.
  1. Waterproofing
   - Opt for a waterproof tarp to effectively protect against rain and moisture. Look for tarps with polyethylene coating or similar waterproofing features.
  1. Securing the Tarp
   - Use bungee cords, ropes, or sturdy straps to secure the tarp to the roof. Ensure it is tightly fastened to prevent wind from lifting or displacing it.
   - Place weights or heavy objects at the tarp's edges to provide additional stability.
  1. Pitch of the Roof
   - Since your roof has a 10/12 pitch, it's a steep slope. Ensure the tarp is securely fastened and consider using additional supports like wooden boards to prevent sliding.
  1. Professional Assistance
   - While a temporary tarp can provide immediate relief, it's crucial to address the underlying roofing issue. Consult with a professional roofer to assess and repair the damage for a more permanent solution.
  1. Local Hardware Stores
   - Visit local hardware stores, home improvement centers, or outdoor supply stores to find a variety of tarps. Staff at these stores can provide advice on choosing the right size and type for your specific needs.
  1. Online Retailers
   - Explore online retailers that specialize in outdoor equipment and tarps. Read product reviews to ensure the tarp meets your requirements.
Remember, a tarp is a temporary fix, and addressing the root cause of the roof issue is crucial. Seek professional assistance if the damage is extensive or if you're unsure about the necessary repairs.
Coffee Conversations - Banner Ad - Supporting LGBTQIA+ Inclusion in Roofing (on-demand)
Everest - Sidebar - Ascend
