BITEC-StormBreaker-Sidebar
WSRCA - Sidebar Ad - Ticket Giveaway
CT_SidebarAd 6-25
Everest - Sidebar - Ascend
METALCON - Sidebar Ad SPAN - METALCON 2025
Commercial building with bad roof deck
March 2, 2017 at 11:31 a.m.
Norrisrfg
I'm working on putting a bid together for a customer. The existing roof has two layers(built up and single ply on top). There are quite a few soft spots when walking around. Went inside to inspect the decking and can tell a lot of steel will need replaced. I'm also told that the business must remain open throughout the entire roofing process. There will definitely be decking that needs to be changed at various times. I'm curious as to what others have done in the past to prevent debris from falling down inside the building? Suspended tarps? Thanks in advance
February 4, 2020 at 4:13 a.m.
Mathew Joseph
Commercial building roofing is now easy with RSH Engineering services.We offer many services for old and new commercial building also our qualified inspection officers gives you the building inspection cost after the review .
For more information:https://www.rshengineering.com/quotes/ /
March 7, 2017 at 12:41 a.m.
What's underneath makes a big difference. A machine shop, and clothing store, a grocery store and a commercial bakery all have different needs, and I've done this on each, and more. Is the BUR asbestos? Is the deck fully exposed? Have made certain that this lion is dead before you decided you wanted to take a bite out of it?
Tremco - Banner Ad - The Global Building Envelope (Mardee Billingsley)
TraceyDonels-June26-PeopleMakeRoofing-SidebarAd
SRS - Sidebar Ad - Your complete source for solar solutions & building products
