CCS-OpenForBusiness-Sidebar
Duro-Last - Sidebar Ad - Quick and easy installation? Time us.
TRA-VideoBrochure-Sidebar
ABC Supply - Sidebar Ad - Take Control of Your Work Day
Everest Systems - Sidebar - Silkoxy Samples - Aug
Cold Seam Welds
January 27, 2025 at 8:04 p.m.
HannahFord7
Issue: An inexperienced roofing crew member improperly welded membrane seams, causing deficient or “cold” welds, which can lead to massive leaks if not corrected.
January 27, 2025 at 8:05 p.m.
HannahFord7
Benchmark Service: Construction Phase Services
Solution: Benchmark field consultants routinely probe seams to ensure proper welding has taken place before the roofing crew leaves the job site. Benchmark’s on-site consultant notified the project manager about the defective hot air welds and worked with the contractor to ensure personnel operating hot air welders were properly trained and supervised.
Possible Impact: Unfortunately, this is a common occurrence as contractors provide on-the-job training using hot air welders. Defective or “cold” welds, if not identified and repaired, will eventually result in open seams or voids allowing moisture to enter the roof system, thereby resulting in wet insulation (reduced R-value), potential product contamination, and in some cases, will negatively impact wind uplift resistance.
SRS - Sidebar Ad (Pinned to Classifieds) - 2025 XTV MLS Tour
